Caller ID - or Number ID?
Postby Blaze1234 » November 30th, 2011, 11:09 pm
Hello, i just recived my Bluestar today and installed in a 2007 Silverado.
My display on the dash shows the phone number - not the name assccoiated to the number. Is this what it is supposed to do?
I use an Iphone 4 - when i do start up the vehicle my name does appear on the dash display.
Any feedback would be appreciated.
Blaze1234
Re: Caller ID - or Number ID?
Postby drivmsafe » December 1st, 2011, 6:47 pm
My '07 Silverado shows only the incoming # also.
drivmsafe
Postby yemiforest » December 2nd, 2011, 10:38 am
Blaze1234 wrote:Hello, i just recived my Bluestar today and installed in a 2007 Silverado.
yes it only shows the number.Where all wating for AD2p. No updates in 8 months
yemiforest
Postby Optimus Prime » December 27th, 2011, 5:43 pm
Can anyone answer these questions? I got my new costar and installed it on my 2003 Avalanche. I have no display of name, caller ID or number, or incoming call number is this normal? I have a fac Nav system and I use a droid x phone. Also I thought while in the middle of a call and the engine is shut down you can still talk? I was in the middle of a call and turned the engine off and it disconnected me from the call.
Thanks in advance for any help ....
Optimus Prime
Postby openbox » December 30th, 2011, 8:22 am
Optimus Prime wrote:Also I thought while in the middle of a call and the engine is shut down you can still talk? I was in the middle of a call and turned the engine off and it disconnected me from the call.
My 04 Silverado maintains the accessory power (~10 minutes) after the engine is turned off as long as the doors remain closed. Once a door is opened (or the ~10 minutes expire), the Bluestar powers down like all other accessories.
openbox
Postby UberGeek » January 6th, 2012, 4:47 pm
openbox wrote:My 04 Silverado maintains the accessory power (~10 minutes) after the engine is turned off as long as the doors remain closed. Once a door is opened (or the ~10 minutes expire), the Bluestar powers down like all other accessories.
That makes sense, but I wonder if the stock OnStar module behaved that way? (I doubt it).
Makes me wonder if the BLUEStar module doesn't/can't draw its power from the same source as the VCM?
UberGeek
Postby mrcostar » January 11th, 2012, 12:19 pm
Actually the onstar module, and therefore the bluestar, get battery power, not reserve power. They should both go into a low power mode when the activity on the vehicle bus quiets down. (After about 10 minutes)
Users browsing this forum: No registered users and 8 guests
