2011 Silverado pictures
Postby HunterG » March 2nd, 2012, 10:45 am
Just finished installing a BlueStar 2010 and thought I would share some pics
Removing the lower dash is all that is required, start with panel below steering wheel (1 10mm bolt and two phillips screws)
Then two 7mm bolts on the center section. Then pull from left side working the clips lose as you go.
I used double sided tape and zip ties to secure the CoStar unit.
Location of OnStar
BlueStar installed
HunterG
Re: 2011 Silverado pictures
Postby mrm13 » June 28th, 2012, 8:01 am
I have a 2010 Silverado with bucket seats and long/big center console, not a bench seat. Does anyone know if the Onstar module is in the same location with that set up? If so, any removal/installation tips?
mrm13
Return to Silverado
