- Press the White OnStar button for one second and get the voice command prompt from your smart phone.
- Press the White OnStar button for three seconds and redial the last number called.
- Press the White OnStar button to answer an incoming call.
- Press the Blue OnStar button to answer an incoming call with the handset instead.
- Press the Red OnStar button to mute a call while connected.
- It recognizes your phone (if present) when you turn on the ignition and connects automatically.
- If multiple phones have been paired, it attempt to connect with them in the order they were added until successful (so your phone trumps your spouses when you are together).
- It comes with a PC-based management/programming utility that includes a ringtone creator function.
- The future A2DP audio out function means streaming PandoraOne. Who needs a satellite radio subscription?
I have worked out a deal with Costar, the makers of Bluestar, to enable our group to get a VW-ready Bluestar for our OnStar-equipped VW Phaetons for $299, shipping included. Email me directly at keith at keithbloom dot com for instructions on overhead button console removal, shipping address and payment. When your button board and payment are received, I will modify the button controller and return it USPS Priority Mail with the VW-enabled Bluestar module and two new harness connectors within 24-48 hours. If you send your button controller by 2-3 day USPS Priority Mail or 2nd Day UPS, your Phaeton should be Bluestar-equipped within a week!
It's ALIVE! (again)
