on star module location
Postby kdonzi123 » April 11th, 2011, 6:56 pm
on the 2005 corvette convertable it is mounted behind the passenger rear storage tray.
kdonzi123
Re: on star module location
Postby dejaspapa » May 21st, 2011, 2:26 pm
kdonzi123, I too have a 2005 Corvette convertible. I could not find the onstar module behind the passenger storage tray. Have you located it? I don't want to tear any more of the interior panels out if I don't have to. Thanks,
dejaspapa
Postby dwcarter » June 8th, 2011, 2:03 pm
I found the Onstar module in the trunk of my 2005 C6 convertible. It is in the passenger side rear storage compartment. If you gently lift the door and pull the liner away from the rear of the comartment, the module is attached to the rear of the compartment.
Onstar Module.JPG (189.68 KiB) Viewed 32614 times
dwcarter
Postby krowe101 » September 9th, 2011, 6:30 am
I have a 2011 C6 Coup. can someone confirm the location of the Onstar Unit in my vehicle.
Thanks Krowe
krowe101
Postby TxPres » December 17th, 2011, 2:43 pm
It is located behind the glove box in the pass side. You do not need to remove the glove box, just the plastic cover that goes from the base of the glove box to the firewall. Very easy, just a couple of pop out plastic rivits.
TxPres
Postby stewkilla » March 1st, 2012, 1:26 pm
Where would the onstar module be located in my 2007 Z06? Also what controls activate the bluestar? I'm interested in buying one but want to do my research first. Thanks
Stew
stewkilla
Postby doug@mark5group.com » July 17th, 2012, 3:09 am
Stew,
Were you able to locate the Onstar for the Z?? I understand it's under the passanger seat. Curious to know how your install when if you have a chance.
Doug
doug@mark5group.com
Return to Corvette
Users browsing this forum: No registered users and 0 guests
