Anyone have iPhone 4 working?
Postby darb21 » April 11th, 2011, 12:16 pm
I can get it to pair and connect, but when the car shuts off and then I come back later, I can't get it to auto-connect at all. Even if I go in and manually tell iPhone to connect, it won't do it until I tell it to forget the Bluestar and then re-pair them. Seems like it only works that first time immediately after pairing. iPhone4 with iOS 4.3.1. I've really not had good luck with iPhone and the Bluestar at all. :(
darb21
Re: Anyone have iPhone 4 working?
Postby eztease » April 12th, 2011, 1:30 pm
Well my Bluestar 2010 and H2 Hummer works flawsly with the iphone 4 in my 2004 H2 Hummer now i just updated to 4.3.1 and i have not driven the rig since, but i will test it out this weekend and if its dosent work i will repost.. Good Luck!
eztease
Postby maxx2200 » April 12th, 2011, 2:09 pm
I have an '05 H2, iPhone 4 and BlueStar2010. I'm having issues with dependability. It will work flawlessly for several "key cycles" (4-5) and then nothing. I'm working with Chris to try and work the bugs out. Any feedback or info would be greatly appreciated.
maxx2200
Postby darb21 » April 12th, 2011, 2:13 pm
Hmm... mine literally fails every single time. Works on that initial pairing, but no automatic reconnect next time I get in the car. I always have to forget the device and re-pair it. Chris, any tips?
darb21
Postby cnauman » April 12th, 2011, 9:00 pm
iPhone 4 / Saturn Outlook
Pairs just fine, occasionally it won't re-pair if I walk out of range but it's pretty rare. Only problem I have is outgoing audio quality, love everything else about it.
cnauman
Postby mrcostar » April 12th, 2011, 9:35 pm
cnauman wrote:iPhone 4 / Saturn Outlook
Have you loaded 11-0401? That might help the re-pair issue when leaving bluetooth range. (~10 meters)
Postby cnauman » April 13th, 2011, 9:54 am
Of course :) I love the caller ID system now!
cnauman
Postby darb21 » April 13th, 2011, 11:17 am
Mine failed to connect again this morning. iPhone sees the Bluestar... Light on mirror is blinking, but they just won't connect. Had to go in on the iPhone and forget the Bluestar, put Bluestar in pairing mode, then re-pair them from the iPhone. I have to do that every time I get in the truck if I want to be able to use it. :(
darb21
Postby cnauman » April 13th, 2011, 3:13 pm
Maybe check the direction your BlueSTAR unit is pointing, I know the instructions are specific in the preferred mounting method.
Just something to check.
cnauman
Postby larry99 » April 18th, 2011, 2:37 pm
iPhone 4 works in GMC Acadia flawlessly. Install was simple. Pairing worked first time and automatically connects when start car again.
larry99
Next
Users browsing this forum: No registered users and 17 guests
