VW Adaptation Successful in OnStar Equipped Tregs!
Postby keithwbloom » November 13th, 2011, 5:48 pm
This solution is for 2004-2005 Touareg owners that have the factory installed analog OnStar option that was declared end of life in 2008 and no upgrade path was provided. This mod does not reincarnate your OnStar services, it uses the OnStar peripherals (cabling and mic) and the phone source capability in the audio system head unit to allow you completely hands-free whole-car audio interface with your Bluetooth 2.1 capable mobile phone. Furthermore, since you have an iPhone(s), you are in for a treat because the voice command options are so plentiful. My Droid X will read incoming email and SMS/MMS messages, dial on command, and search web for whatever I ask it for with the push of the white button in my formerly useless OnStar control panel. I have been told by two other Phaeton owners that Siri (iPhone 4S) works too!
  1. Press the White OnStar button for one second and get the voice command prompt from your smart phone.
  2. Press the White OnStar button for three seconds and redial the last number called.
  3. Press the White OnStar button to answer an incoming call.
  4. Press the Blue OnStar button to answer an incoming call with the handset instead.
  5. Press the Red OnStar button to mute a call while connected.
  • It recognizes your phone (if present) when you turn on the ignition and connects automatically.
  • If multiple phones have been paired, it attempt to connect with them in the order they were added until successful (so your phone trumps your spouses when you are together).
  • It comes with a PC-based management/programming utility that includes a ringtone creator function.
  • The future A2DP audio out function means streaming PandoraOne. Who needs a satellite radio subscription? ;)
I have worked out a deal with Costar, the makers of Bluestar, to enable our group to get a VW-ready Bluestar for our OnStar-equipped VW Touaregs for $299, shipping included. Email me directly at keith at keithbloom dot com for instructions on overhead button console removal, shipping address and payment. When your button board and payment are received, I will modify the button controller and return it USPS Priority Mail with the VW-enabled Bluestar module and two new harness connectors within 24-48 hours. If you send your button controller by 2-3 day USPS Priority Mail or 2nd Day UPS, your Touareg should be Bluestar-equipped within a week!
It's ALIVE! (again) ;)
8-)
keithwbloom
Return to Touareg
Users browsing this forum: No registered users and 7 guests
