Mr CoStar, what about your GM Class 2 Customers
Postby eztease » April 19th, 2011, 8:56 am
Mr CoStar,
Im still waiting for you to do some work for your older customers in getting the Class2 and the DIC to work, we have been very patient awaintg this fix and im starting to loose faith on you working on the class2 codes. my H2 Hummer 2004 still dosent work outside of the blutooh communication, when i had purchased this from you, you stated your were going to fix this function of communication, its been almost 2 years now... can you give us and update on when you plan on getting the caller id to communicate with the DIC or the NAV Stereo system.
eztease
Re: Mr CoStar, what about your GM Class 2 Customers
Postby popper » May 24th, 2011, 12:32 pm
Here here! I would love to see this as well! (06 Avalanche).
popper
Postby cnauman » May 24th, 2011, 9:17 pm
mrcostar wrote:Now a "fix" implies that something is broken. In this case, you are confusing the adding of a feature, with the fixing of a problem. As I am sure you are aware, the BlueSTAR has gone through several enhancements over the last few years, including two major redesigns that will allow the possibility of adding features such as this. Our focus has been working with newer vehicles, and we have made great strides in adding caller Id first to the radio display, then to the DIC.
Unfortunately we have not yet been able to crack the codes to write to the DIC in CLASS2 vehicles. It might even be the case that it is not possible to do so. DIC messages in older vehicles were not all programmable and only fixed messages were displayed. In these cases, there might not be any provisions for the ability to write data to the DIC. We have not given up hope, and continue to look for a solution, but if you purchased the unit before 2010 and have a bluestar pnp, you are out of luck as that unit never was or will be upgradeable for this feature.
The latest version of the CPU program, has the ability to do data logging. If you think you can help solve this problem, take some data captures of the DIC being written to and send them to us for analysis.
Postby UberGeek » January 30th, 2012, 4:33 pm
mrcostar wrote:... CLASS2 based ... will not have caller ID ...
For those of us who still have CLASS2-based vehicles, would you be able to have the number read out in lieu of a ringtone? For example, my Jawbone Icon says "Call from ... 918-254-1130".
UberGeek
Users browsing this forum: No registered users and 13 guests
