Always Muted
Always Muted
Postby jneddo1 » October 20th, 2012, 5:01 pm
Whenever I make a call or receive one it is always muted. Voice dial won't respond unless I hit the red button. Everything worked fine when I first got the Bluestar device then I attempted to upgrade the software and now this issue.... any advise would be greatly appreciated.
jneddo1
Re: Always Muted
Postby mrcostar » October 24th, 2012, 8:08 pm
Installing the older code in the newer hardware will result in the mute function being inverted (default on).
If you need to run older code for some reason, we have a version that inverts the mute signal. Please email techsupport if you need this.
