A2DP STREAMING GM CLASS 2 VEHICLES
Postby BOAKS » May 30th, 2012, 12:30 am
Ok I was having a problem with the Bluestar 2010 and the GM Class 2 electronics. I think I have it solved and woking great now. First take the .cfw from here http://www.costartech.com/forum/viewtopic.php?f=71&t=215 and use that to replace the one in here http://www.costartech.com/forum/viewtopic.php?f=71&t=243 since I replaced the .cfw it has worked perfectly with no problems. Hope this helps some other poeple too. If I run into anything else i'll be sure to let you know.
Ben
BOAKS
Re: A2DP STREAMING GM CLASS 2 VEHICLES
Postby Travis » June 18th, 2012, 8:29 pm
I am also having trouble with my 02 Trailblazer after doing the A2DP update with BES_12_0311. I had to revert back to BES-12-0302 because my Trailblazer went haywire. Every light in the dash started blinking. Any help with this? I would really like to have the ability to use A2DP between my iPhone and Trailblazer. I just bought the unit in late February, and it has the 64MB chip on it.
Any help would be appreciated.
Travis
Postby BOAKS » June 18th, 2012, 8:39 pm
did it work afte the 12-0302.cfw ?
BOAKS
Postby Travis » June 19th, 2012, 7:39 am
When revered back to the older firmware(BES_12-0302), the system does work without the A2DP capability. I was really hoping to be able to use A2DP. Has anyone had success with anything else? After reading all the post, looks like other people with GM Class 2 vehicles are having the same problem. I am not sure if sending it back and having it reloaded at the factory will make any diffence.
Travis
