2006 CTS-V i-Phone 4 disconnect issue.
I have an issue with my phone staying connected when voice dialing. When I press the mirror button the voice dial from the phone works then as the phone is making the call Bluestar drops out. After the drop the phone will not connect to the Bluetar untill It has been re-paired. Then the connection is tenuous at best. Most days it takes 5 -10 minutes to connect and make a call. Normally it will drop at least 3 times before a good connection. Any suggestions?
