A2DP Streaming **** BETA CODE ****
Re: A2DP Streaming **** BETA CODE ****
Postby reverson1 » June 4th, 2012, 5:53 am
Well, while their are a few quirks overall from my experience streaming works well.
    1. no song info on radio
    2. no track controls
    3. I can't receive calls, but I can make calls
    4. there is a thumping noise when it switches back and forth from a2dp and onstar
    5. there is interference that a ground loop isolator doesn't remove (this may be unrelated to a2dp)
However, you do get the stock experience. Which is something that I wanted. Hopefully, the kinks get worked out eventually.
reverson1
Postby bgabbard » June 5th, 2012, 8:47 am
Confirmed open mic while A2DP streaming. Didn't notice it until today but driving 75mph with the windows down it becomes rather noticeable.
bgabbard
Postby reverson1 » June 6th, 2012, 10:53 am
How were able to confirm this?
reverson1
Postby bgabbard » June 6th, 2012, 11:20 am
reverson1 wrote:How were able to confirm this?
bgabbard
Postby reverson1 » June 6th, 2012, 7:45 pm
Sorry, if it seems obvious. But, what was noticeable?
I get a constant noise. I have to turn the treble down all the way for it to go away.
It is very noticeable when I'm listening to podcasts. Is this what you are talking about?
reverson1
Postby bgabbard » June 7th, 2012, 10:31 am
reverson1 wrote:Sorry, if it seems obvious. But, what was noticeable?
No, wind noise from the windows being down. Haven't noticed any other noise.
The phone portion seems to have stopped working too. I hear it ring but then when I answer it runs audio through the phone itself. Steering wheel buttons have ceased to function also. I'm going to plug the onstar module back in for a few days see if that doesn't clear some of my problems up.
bgabbard
Postby bgabbard » June 11th, 2012, 12:25 pm
Yeah phone portion seems completely foobar now. Audio gets directed to handset after I answer and steering wheel controls work like 1 out of hundred times. I guess I just got really lucky that first time. A2DP is working fairly well other than a drop out about 20 seconds after initial connection and the open mic issue.
bgabbard
Postby bgabbard » June 11th, 2012, 4:33 pm
Hey if I wanted to go back to the previous firmware, can I just flash the .CFW file or do I need to do something about the A2DP init string?
bgabbard
Postby Travis » June 18th, 2012, 8:31 pm
I am also having trouble with my 02 Trailblazer after doing the A2DP update with BES_12_0311. I had to revert back to BES-12-0302 because my Trailblazer went haywire. Every light in the dash started blinking. Any help with this? I would really like to have the ability to use A2DP between my iPhone and Trailblazer. I just bought the unit in late February, and it has the 64MB chip on it.
Any help would be appreciated.
Travis
Travis
Previous
Users browsing this forum: No registered users and 21 guests
