iPhone5
Re: iPhone5
Postby Mel » January 11th, 2013, 4:13 pm
6thFairway wrote:I don't use the review view mirror controls except to manually re-pair the bluetooth after it disconnects on answer. I last plugged in a laptop and updated my Bluestar to the lastest software about a month ago... v 12-0718 or whatever (I'm going by memory). I'm driving a 2007 Tahoe.
Just for kicks. Next time time try and answer a call with your rear view mirror controls to see if it works.
Re: iPhone5
Postby olddave » January 13th, 2013, 6:34 pm
I have had the same problem with my iPhone 5. My iPhone 4S worked fine picking up calls. The iPhone 5 has worked only once or twice, but usually drops the call and turns on the radio. My service is with AT&T.
olddave
Re: iPhone5
Postby olddave » January 13th, 2013, 6:36 pm
I've tried to answer both with steering wheel button and mirror button and both drop the call.
olddave
Re: iPhone5
Postby sds67 » January 18th, 2013, 3:25 pm
I was having nothing but problems with the link between iPhone 5 and the Costar, all of which I have heard you all posting. I completely solved the problem by dumping all the phones in the memory of the Costar by holding down the red button on the rear view mirror for 10+ seconds, then re-linked the iPhone 5. Been flawless ever since! I hope this works for everyone else!
sds67
Re: iPhone5
Postby 6thFairway » January 18th, 2013, 4:27 pm
sds67 wrote:I was having nothing but problems with the link between iPhone 5 and the Costar, all of which I have heard you all posting. I completely solved the problem by dumping all the phones in the memory of the Costar by holding down the red button on the rear view mirror for 10+ seconds, then re-linked the iPhone 5. Been flawless ever since! I hope this works for everyone else!
That does not work for me. I've tried it many times.
6thFairway
Re: iPhone5
Postby mrcostar » January 20th, 2013, 10:06 am
Anyone install iOS 6.1 yet?
Hopeful this will help those with this issue.
Still unclear why it effects only some.
Does not seem to be service provider or vehicle related...
Re: iPhone5
Postby dalemeeks » January 22nd, 2013, 11:37 am
I'm having the identical problem. Brand new Bluestar, IPhone 5, Verizon, 2004 SRX with navigation. I can place calls, but not answer them. When unit rings, as soon as I press the call button, the cell phone disconnects, radio comes back on, and indicator light returns to green. Outgoing calls are no problem.
IOS 6.0.2 software installed on IPhone 5.
UPDATE: Sometimes I can answer calls with the Bluestar, but not consistently. Usually the Bluestar breaks the connection when I press the talk button. :twisted:
dalemeeks
Re: iPhone5
Postby 6thFairway » January 24th, 2013, 7:16 pm
This is starting to get very annoying. I'm really hoping iOS 6.1 fixes the problem. I'm in the car commuting 2 to 3 hours a day.
Right now whenever the phone rings I have to quickly turn off the radio (so it doesn't interrupt me when it turns back on), then answer the phone. The phone thinks it's connected to Bluetooth but it''s not, so I have to manually switch the connection back to iphone or speaker so I can answer. At this point, I've left someone hanging for 10 seconds or so, and I'm still scrambling to find a wired headset so I can have the conversation.
6thFairway
Re: iPhone5
Postby chrisA » January 27th, 2013, 4:08 pm
6thFairway wrote:This is starting to get very annoying. I'm really hoping iOS 6.1 fixes the problem. I'm in the car commuting 2 to 3 hours a day.
Sounds like you need more hands for your hands free device!!!
chrisA
Re: iPhone5
Postby Mel » January 28th, 2013, 9:24 pm
FYI iOS 6.1 for apple devices went public today. Hope you all have better luck. Mine work but mine worked before the update.
