Bluestar no longer voice dails
Postby nitehawk79 » June 20th, 2011, 5:40 pm
I installed the Bluestar into my Pontiac and it worked without any issues. I discovered that I could do voice dialing on my Droid X. After a couple weeks the unit no longer responds when I depress the phone button on the mirror. I know the button works because I am able to pick up using it for an incoming call. I removed the Bluestar unit to verify it has the current firmware, which it does (BES_0401). Also is the unit suppose to get power all the time even when the key is off?
thanks,
Scott
nitehawk79
Re: Bluestar no longer voice dails
Postby cnauman » June 22nd, 2011, 9:26 am
How long the power lasts is vehicle specific, should cut out when the door is opened or the vehicles preset time elapses (around 10 minutes I believe).
For the call function, the latest update made it so that you need to press and hold the call button instead of just a quick press. This was done to re-enable the radio mute feature when not on a call.
See if that helps.
cnauman
Postby nitehawk79 » June 23rd, 2011, 6:36 pm
cnauman wrote:How long the power lasts is vehicle specific, should cut out when the door is opened or the vehicles preset time elapses (around 10 minutes I believe).
See if that helps.
cnauman:
Thank you for the reply, I have found that if I launch the voice dial app on the droid that a simple press of the button works for the next few calls. I did try to hold just a little longer and it did nothing and if I held it to long it would redial the last number called.
nitehawk79
Users browsing this forum: No registered users and 4 guests
