2002 GMC Yukon
2002 GMC Yukon
Postby bilr777 » September 26th, 2011, 10:57 pm
I want to install this on my 2002 Yukon SLT. Is Blue star 2010 compatible?
Thanks
bilr777
Re: 2002 GMC Yukon
Postby mrcostar » September 27th, 2011, 10:14 am
Probably not.
Most truck switched over to the newer style in 2003.
Check your onstar box. RED and BLUE connectors = no good.
White connectors = Good.
Re: 2004 GMC Yukon
Postby ron » February 4th, 2012, 5:01 pm
Is there a photo that identifies the On star module and exactly where the wires are and how to disconnect?
ron
Re: 2002 GMC Yukon
Postby mrcostar » February 7th, 2012, 8:44 pm
I nearly trucks its usually behind the glove box.
Old Analog unit has RED and BLUE connectors and is a two module solution. Newer unit is one box with white connectors.
Re: 2002 GMC Yukon
Postby Kelseye » February 14th, 2012, 4:50 am
Well i think it's not compatible with it. If you give some pictures of it then it will be easy to answer you.
Kelseye
Return to Yukon
