by flenn » February 28th, 2013, 9:37 am
Just want to chime in quickly. This is the best thread for anyone with a Yukon/Tahoe/Suburban on how to install the Bluestar unit. While waiting for mine to arrive, I googled/searched how to install in my Yukon XL and this was hand's down the best info. Thanks to OP for pictures and detailed installation information. After reading that some others were able to install without removing the front components, I knew that I would try this first. Well, it took me more time to find the proper tools than it did to actually install the Bluestar. One poster said 10 minutes, and that really is accurate. Here's my 2 cents:
1) Taking the trim piece off near the foot pedal feels like you're going to break it. Just try to grab from in back (near the clips) and pull/wiggle until it lets go.
2) Taking off the metal bracket is straightforward.
3) Get a flashlight and position it out of the way so that you can reach in. You should be able to see J1 and J2 easily. Grab the wire harness and pull it out of your way so that you can get a direct shot at the connectors. There should be plenty of slack.
4) Here's where I lost time: I found a 12" gasket scraper type tool to reach in and get the blade between the connectors and Onstar unit. It worked great although I'm certain that any large blade flathead screwdriver would work. Twisting the tool will pry the connector out, only problem is that you have to press down on the top of the connector while prying. I spent the next 20 minutes or so looking for a right angle tool to press down. It was difficult using two tools at the same time from in back and I just couldn't find anything that could press down effectively. Then, in a fit of frustration, I tried to reach in there with my hand while twisting the tool. It worked like a charm! Should have done that 20 minutes ago! Both connectors came right out and the install was simple. My hands are not huge, but they're not small. I would think most anyone can get their hands in there, even though it may not look like it.
Anyway, just letting you guys know that you should be able to do the entire install from the back (don't remove the radio, hvac, etc.) and it should go pretty quickly. Good luck!
