2008 Equinox
2008 Equinox
Postby slotzero » November 29th, 2013, 7:31 pm
I was able to do this install by just removing the under dash panel - two 7mm bolts, then pull forward to release the clips. First bolt is in the little compartment to the left of the steering wheel, second is on the right close to the center console.
Others have said it is impossible to remove the connections from the OnStar unit without removing it but this is not the case. If you grab a medium-sized flathead screwdriver, you can use that with leverage from the OnStar bracket to pull them out easily. Just line up the screwdriver with the clip tab, then pull the screwdriver towards the steering wheel - the connector with slide right out.
On the 2008 Equinox, the plastic in front of the OnStar unit has a perfect sized "cubby" for the BlueSTAR - I just stuck a small piece of 3M two-sided tape and pressed it in there to keep it from rattling around.
:mrgreen:
slotzero
Return to Equinox
Users browsing this forum: No registered users and 2 guests
